Reporting Engine Fails (com/lowagie/text/html/HtmlEncoder)
Hey Everyone,
I am trying to use the reporting extension in RM 5 RC. When I try to run the example process from http://rapid-i.com/enterprise_information/reporting_engine.html I get an error telling me I am missing an HTML encoder.
It looks like I am missing the iText library. Does anyone know how to make this work Under Windows 7 64 bit?
Here is my stack trace:
Exception: java.lang.NoClassDefFoundError
Message: com/lowagie/text/html/HtmlEncoder
Stack trace:
com.rapidminer.report.HTMLReportStream.addSection(HTMLReportStream.java:442)
com.rapidminer.report.HTMLReportStream.startSection(HTMLReportStream.java:402)
com.rapidminer.operator.report.SectionReporter.doWork(SectionReporter.java:82)
com.rapidminer.operator.Operator.execute(Operator.java:767)
com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:51)
com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:709)
com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:363)
com.rapidminer.operator.ProcessRootOperator.doWork(ProcessRootOperator.java:345)
com.rapidminer.Process.run(Process.java:745)
com.rapidminer.Process.run(Process.java:689)
com.rapidminer.Process.run(Process.java:665)
com.rapidminer.Process.run(Process.java:655)
com.rapidminer.gui.ProcessThread.run(ProcessThread.java:65)
Cause
Exception: java.lang.ClassNotFoundException
Message: com.lowagie.text.html.HtmlEncoder
Stack trace:
java.net.URLClassLoader$1.run(URLClassLoader.java:200)
java.security.AccessController.doPrivileged(Native Method)
java.net.URLClassLoader.findClass(URLClassLoader.java:188)
java.lang.ClassLoader.loadClass(ClassLoader.java:303)
java.lang.ClassLoader.loadClass(ClassLoader.java:248)
java.lang.ClassLoader.loadClassInternal(ClassLoader.java:316)
1 - 8 of
81
thank you for this hint. Although I did not cope to reproduce the problem, I noticed, that this sample process dates back to 4.2(!). It not even works after importing, since there are several operators used not present int the 4.5.
I will keep on checking...
Greetings,
Sebastian
Greetings,
Sebastian
-Gagi
