<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="-20" width="-50"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="131" y="90"/> <operator activated="true" class="rename" expanded="true" height="76" name="Rename" width="90" x="327" y="98"> <parameter key="old_name" value="att1"/> <parameter key="new_name" value="pregnant"/> </operator> <operator activated="true" class="discretize_by_user_specification" expanded="true" height="94" name="Discretize" width="90" x="530" y="95"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="pregnant"/> <list key="classes"> <parameter key="flow" value="1.0"/> <parameter key="medium" value="6.0"/> <parameter key="high" value="Infinity"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
