<?xml version="1.0" encoding="UTF-8"?><process version="4.6"> <operator name="Root" class="Process" expanded="yes"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <operator name="ExcelExampleSource" class="ExcelExampleSource"> <parameter key="excel_file" value="data.xls"/> <parameter key="sheet_number" value="1"/> <parameter key="row_offset" value="0"/> <parameter key="column_offset" value="0"/> <parameter key="first_row_as_names" value="true"/> <parameter key="create_label" value="true"/> <parameter key="label_column" value="27"/> <parameter key="create_id" value="false"/> <parameter key="id_column" value="1"/> <parameter key="decimal_point_character" value="."/> <parameter key="datamanagement" value="double_array"/> </operator> <operator name="XValidation" class="XValidation" expanded="yes"> <parameter key="keep_example_set" value="false"/> <parameter key="create_complete_model" value="true"/> <parameter key="average_performances_only" value="true"/> <parameter key="leave_one_out" value="false"/> <parameter key="number_of_validations" value="10"/> <parameter key="sampling_type" value="stratified sampling"/> <parameter key="local_random_seed" value="-1"/> <operator name="DecisionTree" class="DecisionTree"> <parameter key="keep_example_set" value="false"/> <parameter key="criterion" value="information_gain"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_gain" value="0.1"/> <parameter key="maximal_depth" value="20"/> <parameter key="confidence" value="0.25"/> <parameter key="number_of_prepruning_alternatives" value="3"/> <parameter key="no_pre_pruning" value="true"/> <parameter key="no_pruning" value="false"/> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier" class="ModelApplier"> <parameter key="keep_model" value="false"/> <list key="application_parameters"> </list> <parameter key="create_view" value="false"/> </operator> <operator name="Performance" class="Performance"> <parameter key="keep_example_set" value="false"/> <parameter key="use_example_weights" value="true"/> </operator> </operator> </operator> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <parameter key="logverbosity" value="3"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="1"/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="parallelize_main_process" value="false"/> <process expanded="true" height="505" width="681"> <operator activated="true" class="read_excel" expanded="true" height="60" name="Read Excel" width="90" x="45" y="120"> <parameter key="excel_file" value="data.xls"/> <parameter key="sheet_number" value="1"/> <parameter key="row_offset" value="0"/> <parameter key="column_offset" value="0"/> <parameter key="first_row_as_names" value="true"/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="179" y="30"> <parameter key="name" value="Label"/> <parameter key="target_role" value="label"/> </operator> <operator activated="true" class="x_validation" expanded="true" height="112" name="Validation" width="90" x="581" y="165"> <parameter key="create_complete_model" value="false"/> <parameter key="average_performances_only" value="true"/> <parameter key="leave_one_out" value="false"/> <parameter key="number_of_validations" value="10"/> <parameter key="sampling_type" value="2"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="parallelize_training" value="false"/> <parameter key="parallelize_testing" value="false"/> <process expanded="true" height="741" width="397"> <operator activated="true" class="decision_tree" expanded="true" height="76" name="Decision Tree" width="90" x="112" y="30"> <parameter key="criterion" value="information_gain"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_gain" value="0.1"/> <parameter key="maximal_depth" value="20"/> <parameter key="confidence" value="0.25"/> <parameter key="number_of_prepruning_alternatives" value="3"/> <parameter key="no_pre_pruning" value="true"/> <parameter key="no_pruning" value="false"/> </operator> <connect from_port="training" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true" height="741" width="397"> <operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="77" y="53"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance" expanded="true" height="76" name="Performance" width="90" x="246" y="75"> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> <connect from_op="Read Excel" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Validation" to_port="training"/> <connect from_op="Validation" from_port="model" to_port="result 1"/> <connect from_op="Validation" from_port="training" to_port="result 3"/> <connect from_op="Validation" from_port="averagable 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
Age F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 F13 F14 F15 F16 F17 F18 F19 F20 F21 F22 F23 F24 F25 Label71 YES YES L1 NO NO NO NO No No No No No No No No No No Yes No No No No No No No C160 YES NO L1 NO NO NO NO No No No No No No No No No No No No Yes No No No No No C156 YES YES L1 NO NO NO NO No No No No No No No No No No Yes No No No No No No No C147 YES NO L1 NO NO NO NO No No No No No No No No No Yes No No No No No No No No C258 YES NO L1 NO NO NO NO No No No No No No No No No No No Yes No No No No No No C269 YES NO L1 NO NO NO NO No No No No No No No No No No No Yes No No No No No No C266 YES NO L1 NO NO NO NO No No No No No No No No No Yes No No No No No No No No C252 YES NO L1 NO NO NO NO No No No No No No No No No Yes No No No No No No No No C255 YES NO L1 NO NO NO NO No No No No No No No No No No No Yes No No No No No No C271 YES NO L1 NO NO NO NO No No No No No No No No No Yes No No No No No No No No C272 YES YES L1 NO NO NO NO No No No No No No No No No No Yes Yes No No No No No No C150 YES NO L2 NO NO NO NO No No No No No No No No No No No No No Yes No No No No C238 YES NO L2 NO NO NO NO No No No No No No No No No No No No No Yes No No No No C277 YES NO L3 NO NO NO NO No Yes No No No Yes Yes No No No No No No No No No No No C252 YES NO L3 NO NO YES NO Yes Yes No No No No No No No Yes No No No No No No No No C269 YES NO L3 NO NO NO NO No Yes No No No No Yes No Yes No No No No No No No No No C164 NO NO L3 NO NO NO NO No Yes Yes No No Yes No No No No No No No No No No No No C158 NO NO L3 NO NO YES NO Yes No No No No Yes No No No No No No No No No No No No C183 NO NO L3 NO NO NO NO Yes Yes No No No Yes No No No No No No No No No No No No C169 YES NO L3 NO YES NO YES No No No No No Yes No No No No No No No No No No No No C248 YES NO L3 NO NO YES NO No Yes No No No No Yes No Yes Yes No No No No No No No No C268 YES NO L3 NO NO NO NO No Yes No No No Yes Yes No No No No No No No No No No No C168 YES NO L3 NO NO NO NO No Yes No No No No Yes No No No No No No No No No No No C140 NO YES L3 NO NO NO NO No No No No No Yes No Yes No No No No No No No No No No C183 YES NO L3 NO NO NO NO No No No No No Yes No No No No No No No No No No No No C162 YES NO L3 NO NO NO NO No Yes No No No Yes Yes Yes Yes No No No No No No No No No C265 YES NO L3 NO NO YES NO No Yes No No No Yes Yes No No No No No No No No No No No C173 NO NO L3 NO NO YES NO No Yes No No No Yes Yes No No No No No No No No No No No C268 YES NO L3 NO NO NO NO No Yes No No No Yes No Yes No No No No No No No No No No C260 NO YES L3 YES NO NO NO No No No No No Yes No No No No No No No No No No No No C152 NO NO L3 NO NO NO NO No Yes No No No No Yes No No No No No No No No No No No C162 YES NO L3 YES NO NO NO No Yes No No No Yes No No Yes No No No No No No No No No C272 YES NO L3 NO NO NO NO Yes Yes No No No No Yes No Yes No No No No No No No No No C282 YES NO L3 NO NO NO NO No Yes No No No No Yes No Yes No No No No No No No No No C281 YES NO L3 NO NO NO NO Yes Yes Yes No No Yes Yes No Yes No No No No No No No No No C159 NO NO L4 NO NO NO NO No No No No No No No Yes No No No No No No No No No No C159 NO NO L4 NO NO YES NO No No No No No No No Yes No No No No No No No No No No C162 YES NO L4 NO NO NO NO No No No No No No No Yes No No No No No No No No No No C156 YES NO L7 NO NO NO NO No No No No No No No No No No No No No No No No Yes No C261 YES NO L2 NO NO NO NO No No No No No No No No No No No No No Yes No No No No C243 NO NO L2 NO NO NO NO No No No No No No No No No No Yes No No No No No No No C162 YES NO L2 NO NO NO NO No No No No No No No No No Yes No No No No No No No No C230 NO NO L2 NO NO NO YES No No No No No No No No No No Yes No No No No No No No C169 YES NO L5 NO NO YES NO No No No No No No No No No No Yes No No No No No No No C142 NO NO L5 NO NO NO NO No No No No No No No Yes No No No No Yes No No No No No C262 NO YES L5 NO NO NO NO No No No No No No No Yes No No No No Yes No No No No No C262 YES NO L5 NO NO NO YES No No No No No No No No No No No No No No No No No No C255 NO YES L5 NO NO NO NO No No No No No No No No No No Yes No No No No No No No C172 NO NO L5 NO NO NO NO No No No No No No No No No No No Yes No No No No No No C275 YES YES L5 NO NO NO NO No No No No No No No No No No No No No No No Yes No No C276 YES NO L6 NO NO NO NO No No No No No No No No No No No No No No No No No No C266 YES NO L6 NO NO NO NO No No No No No No No No No No No No No No Yes No No No C176 YES NO L6 NO NO NO NO No No No No No No No No No No No No No Yes No No No No C285 YES NO L6 NO NO NO NO No No No No No No No No No No No No No No Yes No No No C275 YES NO L6 NO NO NO NO No No No No No No No No No No No No No No No No No No C265 NO NO L6 NO NO NO YES No No No No No No No No No Yes No No No No No No No No C230 NO NO L6 NO NO NO YES No No No No No No No No No No No No No No No No No No C130 NO NO L6 NO NO NO YES No No No No No No No Yes No No No No No No No No No No C174 NO NO L6 NO NO NO NO No No No No No No No No No No Yes No No No No No No No C169 YES NO L6 NO NO NO NO No No No No Yes No No No No No No No No No No No No No C262 YES NO L6 NO NO NO NO No No No No No No No No No No Yes No No No No No No No C166 YES NO L6 NO NO NO NO No No No No No No No No No No No No No No No No No Yes C263 NO NO L6 NO NO NO YES No No No No No No No No No No No Yes No No No No No No C263 NO NO L6 NO NO NO YES No No No No No No No No No No Yes No No No No No No No C163 NO NO L6 NO NO NO NO No No No No No No No No No No Yes No No No No No No No C160 YES NO L6 NO NO NO YES No No No Yes No No No No No No No No No No No No No No C260 NO NO L6 NO NO NO YES No No No No No No No No No No Yes No No No No No No No C164 YES NO L6 NO NO NO NO No No No No No No No No No No No No No Yes No No No No C249 YES NO L6 NO NO NO NO No No No No No No No No No No No Yes No No No No No No C273 YES NO L6 NO NO NO NO No No No No No No No No No No No No No No No No Yes No C250 NO NO L6 NO NO NO YES No No No No No No No Yes No No No No No No No No No No C182 NO NO L6 NO NO NO NO No No No No No No No Yes No No No No No No No No No No C167 YES NO L6 NO NO NO NO No No No No No No No No No No No No No No No No No No C252 NO NO L6 NO NO NO NO No No No No No No No Yes No No No No No No No No No No C152 YES NO L6 NO NO NO NO No No No Yes No No No No No No No No No No No No No No C257 YES NO L6 NO NO NO NO No No No No No No No No No No No Yes No No No No No No C253 YES NO L6 NO NO NO NO No No No No No No No Yes No No No No No No No No No No C252 YES NO L6 NO NO NO NO No No No No No No No Yes No No No No No No No No No No C178 NO NO L6 NO NO NO NO No No No No No No No No No No Yes No No No No No No No C169 YES NO L6 NO NO NO YES No No No No No No No No No No Yes No No No No No No No C269 NO NO L6 NO NO NO YES No No No No No No No No No No Yes No No No No No No No C173 NO NO L6 NO NO NO NO No No No No No No No No No No Yes No No No No No No No C159 YES NO L6 NO NO NO NO No No No No No No No No No Yes No No No No No No No No C265 NO NO L6 NO NO NO NO No No No No No No No Yes No No No No No No No No No No C278 YES NO L6 NO NO NO NO No No No No No No No No No Yes No No No No No No No No C276 YES NO L6 NO NO NO NO No No No No No No No No No No No No No No No No Yes No C276 YES NO L6 NO NO NO NO No No No No No No No No No No No Yes No No No No No No C273 YES NO L6 NO NO NO NO No No No No No No No No No No No No No Yes No No No No C279 YES NO L6 NO NO NO NO No No No No No No No No No Yes No No No No No No No No C2
