Connecting with SQL Server Express 2005
I am new to Rapid Miner.
I have just installed the new version of RM (5.0) and I am trying to connect to a SQL server (Express) database on the same home machine. For some reason it always gives me an error.
Even though i did download the driver(http://www.microsoft.com/downloads/details.aspx?familyid=C47053EB-3B64-4794-950D-81E1EC91C1BA&displaylang=en) and copied both the .jar files into the /lib folder, when i look under Tools -> Database Drivers, the SQL Server (Microsoft) driver is not enabled.
Can anyone help me with this?
Thanks in advance.
Jake
Thanks in advance.
Jake
1 - 6 of
61
Hi haddock,
Many thanks for your reply.
I am using the wizard available with RM5 and it still gives me an error using the JTDS driver.
The specific error I am getting is " Please check your connection settings and revalidate the connection URL: 'jdbc:jtds:sqlserver://localhost:1433/dbschemaname'.
Would be great if you could help!
Cheers,
Jake
Cheers,
Jake
Are you using a Named Instance on the SQL Server?
if so, change your connection string to this:
jdbc:jtds:sqlserver://domain:1433/databasename;instance=sqlexpress
http://www.youtube.com/user/VancouverData
please copy the driver into the /lib/jdbc directory. This is the only path searched automatically. Please tell me, if this does not work either.
Greetings,
Sebastian
