Hi all,
I have the below process. Now, obviously, in the current state, it doesn't make much sense, but it's the result of trying to isolate a very strange behavior. Let me explain:
The performance vector calculated changes completely when I remove the Model Applier with the name
Apply Error. This is (at least to me) unexpected, since the only operators which use random numbers (Sample and MetaCost) have hard-wired local random seeds.
When I change the operator execution order so that
Apply Error comes last, I get the same results as if I remove
Apply Error ...
Obviously, the eventual goal is to route the output of
Apply Error to the model coming out of MetaCost. The reason for all this is that a cross-validation gives me better results than if I test against entirely virgin data - my suspicion is that I have insufficient information in my attribute set - but now of course this strange behavior of RM-5 casts some doubt on the entire exercise.
I'm willing to share the underlying .csv with Rapid-I (of course assuming confidentiality) if this helps understanding the issue further.
Kind regards Stefan
<process version="5.0">
<context>
<input>
<location/>
</input>
<output>
<location/>
<location/>
<location/>
<location/>
</output>
<macros/>
</context>
<operator activated="true" class="process" expanded="true" name="Process">
<process expanded="true" height="746" width="975">
<operator activated="true" class="read_csv" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30">
<parameter key="file_name" value="C:\Users\eichenbe\Documents\Backup\Laptop\LiveCopy\Software\RapidMiner_5\32401_P.csv"/>
<operator activated="true" class="set_role" expanded="true" height="76" name="Set ID" width="90" x="179" y="30">
<parameter key="name" value="DieID"/>
<operator activated="true" class="numerical_to_binominal" expanded="true" height="76" name="Numerical to Binominal" width="90" x="313" y="30">
<parameter key="attribute" value="t_32401"/>
<parameter key="max" value="74.1"/>
<operator activated="true" class="remap_binominals" expanded="true" height="76" name="Remap Binominals" width="90" x="447" y="30">
<parameter key="negative_value" value="false"/>
<parameter key="positive_value" value="true"/>
<operator activated="true" class="multiply" expanded="true" height="94" name="Multiply" width="90" x="581" y="30"/>
<operator activated="true" class="filter_examples" expanded="true" height="76" name="Filter Training (2)" width="90" x="45" y="300">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="Wafer<=6"/>
<operator activated="true" class="remove_attribute_range" expanded="true" height="76" name="Remove Wafer (2)" width="90" x="179" y="300">
<parameter key="first_attribute" value="2"/>
<parameter key="last_attribute" value="2"/>
<operator activated="true" class="set_role" expanded="true" height="76" name="Set Label (2)" width="90" x="313" y="300">
<parameter key="name" value="t_32401"/>
<operator activated="true" class="filter_examples" expanded="true" height="76" name="Filter Training" width="90" x="45" y="165">
<operator activated="true" class="remove_attribute_range" expanded="true" height="76" name="Remove Wafer" width="90" x="179" y="165">
<operator activated="true" class="set_role" expanded="true" height="76" name="Set Label" width="90" x="313" y="165">
<operator activated="true" class="normalize" expanded="true" height="94" name="Normalize" width="90" x="447" y="165"/>
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Error" width="90" x="447" y="300">
<operator activated="true" class="sample" expanded="true" height="76" name="Sample" width="90" x="581" y="165">
<parameter key="sample" value="relative"/>
<parameter key="sample_ratio" value="0.3"/>
<parameter key="use_local_random_seed" value="true"/>
<operator activated="true" class="metacost" expanded="true" height="76" name="MetaCost (2)" width="90" x="715" y="165">
<parameter key="cost_matrix" value="[0.0 1.0;10.0 0.0]"/>
<parameter key="use_subset_for_training" value="0.7"/>
<parameter key="local_random_seed" value="100"/>
<process expanded="true" height="773" width="912">
<operator activated="true" class="support_vector_machine_libsvm" expanded="true" height="76" name="SVM (2)" width="90" x="411" y="30">
<parameter key="gamma" value="0.01"/>
<parameter key="C" value="10000.0"/>
<list key="class_weights"/>
<connect from_port="training set" to_op="SVM (2)" to_port="training set"/>
<connect from_op="SVM (2)" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<operator activated="true" class="apply_model" expanded="true" height="76" name="Apply Model" width="90" x="715" y="300">
<operator activated="true" class="performance_binominal_classification" expanded="true" height="76" name="Performance" width="90" x="715" y="435">
<parameter key="main_criterion" value="precision"/>
<parameter key="AUC (optimistic)" value="true"/>
<parameter key="precision" value="true"/>
<parameter key="false_positive" value="true"/>
<parameter key="false_negative" value="true"/>
<parameter key="true_positive" value="true"/>
<parameter key="true_negative" value="true"/>
<connect from_op="Read CSV" from_port="output" to_op="Set ID" to_port="example set input"/>
<connect from_op="Set ID" from_port="example set output" to_op="Numerical to Binominal" to_port="example set input"/>
<connect from_op="Numerical to Binominal" from_port="example set output" to_op="Remap Binominals" to_port="example set input"/>
<connect from_op="Remap Binominals" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Filter Training" to_port="example set input"/>
<connect from_op="Multiply" from_port="output 2" to_op="Filter Training (2)" to_port="example set input"/>
<connect from_op="Filter Training (2)" from_port="example set output" to_op="Remove Wafer (2)" to_port="example set input"/>
<connect from_op="Remove Wafer (2)" from_port="example set output" to_op="Set Label (2)" to_port="example set input"/>
<connect from_op="Set Label (2)" from_port="example set output" to_op="Apply Error" to_port="unlabelled data"/>
<connect from_op="Filter Training" from_port="example set output" to_op="Remove Wafer" to_port="example set input"/>
<connect from_op="Remove Wafer" from_port="example set output" to_op="Set Label" to_port="example set input"/>
<connect from_op="Set Label" from_port="example set output" to_op="Normalize" to_port="example set input"/>
<connect from_op="Normalize" from_port="example set output" to_op="Sample" to_port="example set input"/>
<connect from_op="Normalize" from_port="preprocessing model" to_op="Apply Error" to_port="model"/>
<connect from_op="Sample" from_port="example set output" to_op="MetaCost (2)" to_port="training set"/>
<connect from_op="MetaCost (2)" from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_op="MetaCost (2)" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="model" to_port="result 1"/>
<connect from_op="Performance" from_port="performance" to_port="result 2"/>
<connect from_op="Performance" from_port="example set" to_port="result 3"/>
</process>
</process>
