<operator name="Count class sizes" class="OperatorChain" expanded="yes"> <operator name="ValueIterator" class="ValueIterator" expanded="no"> <parameter key="attribute" value="target_"/> <parameter key="iteration_macro" value="target_value"/> <operator name="ExampleFilter" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="target_=%{target_value}"/> </operator> <operator name="DataMacroDefinition" class="DataMacroDefinition"> <parameter key="macro" value="class_size"/> </operator> <operator name="echo the target value" class="CommandLineOperator"> <parameter key="command" value="echo " class '%{target_value}' size = %{class_size}""/> <parameter key="log_stderr" value="false"/> </operator> </operator> <operator name="ExampleSetMerge" class="ExampleSetMerge"> </operator> </operator>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input> <location/> </input> <output> <location/> <location/> </output> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="280" width="413"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="112" y="165"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="aggregate" expanded="true" height="76" name="Aggregate" width="90" x="246" y="165"> <list key="aggregation_attributes"> <parameter key="label" value="count"/> </list> <parameter key="group_by_attributes" value="label"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="341" width="614"> <operator activated="true" class="generate_data" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="target_function" value="single gaussian cluster"/> <parameter key="number_examples" value="500"/> <parameter key="number_of_attributes" value="3"/> </operator> <operator activated="true" class="discretize_by_bins" expanded="true" height="94" name="Discretize" width="90" x="179" y="30"> <parameter key="number_of_bins" value="5"/> <parameter key="range_name_type" value="short"/> </operator> <operator activated="true" class="remember" expanded="true" height="60" name="Remember" width="90" x="313" y="30"> <parameter key="name" value="filtered_data"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="loop_attributes" expanded="true" height="60" name="Loop Attributes" width="90" x="447" y="30"> <process expanded="true" height="603" width="626"> <operator activated="true" class="aggregate" expanded="true" height="76" name="Aggregate" width="90" x="45" y="30"> <list key="aggregation_attributes"> <parameter key="label" value="count"/> </list> <parameter key="group_by_attributes" value="%{loop_attribute}"/> </operator> <operator activated="true" class="sort" expanded="true" height="76" name="Sort" width="90" x="179" y="30"> <parameter key="attribute_name" value="count(label)"/> <parameter key="sorting_direction" value="decreasing"/> </operator> <operator activated="true" class="filter_example_range" expanded="true" height="76" name="Filter Example Range" width="90" x="313" y="30"> <parameter key="first_example" value="1"/> <parameter key="last_example" value="3"/> <parameter key="invert_filter" value="true"/> </operator> <operator activated="true" class="loop_values" expanded="true" height="60" name="Loop Values" width="90" x="447" y="30"> <parameter key="attribute" value="%{loop_attribute}"/> <process expanded="true" height="603" width="626"> <operator activated="true" class="recall" expanded="true" height="60" name="Recall (2)" width="90" x="45" y="30"> <parameter key="name" value="filtered_data"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="filter_examples" expanded="true" height="76" name="Filter Examples" width="90" x="179" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="%{loop_attribute} = %{loop_value}"/> <parameter key="invert_filter" value="true"/> </operator> <operator activated="true" class="remember" expanded="true" height="60" name="Remember (2)" width="90" x="313" y="30"> <parameter key="name" value="filtered_data"/> <parameter key="io_object" value="ExampleSet"/> </operator> <connect from_op="Recall (2)" from_port="result" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Remember (2)" to_port="store"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> </process> </operator> <connect from_port="example set" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Loop Values" to_port="example set"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> </process> </operator> <operator activated="true" class="recall" expanded="true" height="60" name="Recall" width="90" x="447" y="120"> <parameter key="name" value="filtered_data"/> <parameter key="io_object" value="ExampleSet"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Discretize" to_port="example set input"/> <connect from_op="Discretize" from_port="example set output" to_op="Remember" to_port="store"/> <connect from_op="Remember" from_port="stored" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Recall" from_port="result" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
