<operator name="Root" class="Process" expanded="yes"> <operator name="Generate 100 Examples Numerical label, 5 numerical, 5 nominal attributes" class="OperatorChain" expanded="no"> <operator name="Generate Regression Problem" class="ExampleSetGenerator"> <parameter key="target_function" value="polynomial"/> </operator> <operator name="IdTagging" class="IdTagging"> </operator> <operator name="Generate Nominal Attributes" class="NominalExampleSetGenerator"> <parameter key="number_of_values" value="2"/> </operator> <operator name="IdTagging 2" class="IdTagging"> </operator> <operator name="ExampleSetJoin" class="ExampleSetJoin"> <parameter key="remove_double_attributes" value="false"/> </operator> <operator name="Store the combined data set" class="IOStorer"> <parameter key="name" value="AllData"/> <parameter key="io_object" value="ExampleSet"/> </operator> </operator> <operator name="Get back a COPY of the Data set" class="IORetriever"> <parameter key="name" value="AllData"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="remove_from_store" value="false"/> </operator> <operator name="Remove nominal attributes" class="FeatureValueTypeFilter"> </operator> <operator name="LinearRegression" class="LinearRegression"> <parameter key="keep_example_set" value="true"/> <parameter key="eliminate_colinear_features" value="false"/> <parameter key="use_bias" value="false"/> </operator> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="Get another COPY of the whole dataset" class="IORetriever"> <parameter key="name" value="AllData"/> <parameter key="io_object" value="ExampleSet"/> <parameter key="remove_from_store" value="false"/> </operator> <operator name="Restore the Nominals" class="ExampleSetJoin"> </operator></operator>
