<operator name="Root" class="Process" expanded="yes"> <operator name="FeatureExtraction" class="FeatureExtraction"> <list key="texts"> <parameter key="ADC" value="../01 Data/Model Patents/ADC"/> <parameter key="DAC" value="../01 Data/Model Patents/DAC"/> <parameter key="Supply" value="../01 Data/Model Patents/Supply"/> <parameter key="ESD" value="../01 Data/Model Patents/ESD"/> <parameter key="IO" value="../01 Data/Model Patents/IO"/> <parameter key="Non_Volatile" value="../01 Data/Model Patents/Flash"/> <parameter key="PLL" value="../01 Data/Model Patents/PLL"/> <parameter key="DLL" value="../01 Data/Model Patents/DLL"/> <parameter key="Process" value="../01 Data/Model Patents/Process"/> <parameter key="Package" value="../01 Data/Model Patents/Package"/> <parameter key="Amplifer" value="../01 Data/Model Patents/Amplifier"/> <parameter key="MEMS" value="../01 Data/Model Patents/MEMS"/> <parameter key="Optoelectronics" value="../01 Data/Model Patents/Optoelectronics"/> </list> <parameter key="id_attribute_type" value="short"/> <list key="attributes"> <parameter key="XTitle" value="//x:title[@language=&#39;en']/text()"/> <parameter key="XAbstract" value="//x:abstract/x:paragraph/text()"/> </list> <list key="namespaces"> <parameter key="x" value="http://schemas.delphion.com/20031014/ippublication"/> </list> </operator> <operator name="Nominal2String" class="Nominal2String"> </operator> <operator name="StringTextInput" class="StringTextInput" expanded="no"> <parameter key="remove_original_attributes" value="true"/> <parameter key="id_attribute_type" value="short"/> <list key="namespaces"> </list> <operator name="StringTokenizer" class="StringTokenizer"> </operator> <operator name="EnglishStopwordFilter" class="EnglishStopwordFilter"> </operator> <operator name="TokenLengthFilter" class="TokenLengthFilter"> <parameter key="min_chars" value="2"/> <parameter key="max_chars" value="15"/> </operator> <operator name="PorterStemmer" class="PorterStemmer"> </operator> </operator> <operator name="SVMWeighting" class="SVMWeighting"> </operator> <operator name="AttributeWeightSelection" class="AttributeWeightSelection"> <parameter key="weight_relation" value="top k"/> <parameter key="k" value="500"/> </operator> <operator name="ExampleSet2AttributeWeights" class="ExampleSet2AttributeWeights"> </operator> <operator name="AttributeWeightsWriter" class="AttributeWeightsWriter"> <parameter key="attribute_weights_file" value="%{process_name}_AttrWeight.wgt"/> </operator> <operator name="Binary2MultiClassLearner" class="Binary2MultiClassLearner" expanded="yes"> <operator name="Weighted Class" class="LibSVMLearner"> <parameter key="kernel_type" value="linear"/> <parameter key="C" value="10.0"/> <list key="class_weights"> <parameter key="Clocking" value="2.0"/> <parameter key="Memory" value="2.0"/> <parameter key="Converter" value="2.0"/> <parameter key="Process" value="3.0"/> <parameter key="Package" value="3.0"/> <parameter key="IO" value="2.0"/> <parameter key="ESD" value="2.0"/> <parameter key="Supply" value="2.0"/> </list> <parameter key="calculate_confidences" value="true"/> </operator> </operator> <operator name="ModelWriter" class="ModelWriter"> <parameter key="model_file" value="%{process_name}_Model.mod"/> <parameter key="output_type" value="XML"/> </operator></operator>
