Can the export block export strings?
User: "Jeff_wu"
Altair Community Member
Updated by Jeff_wu
I attempted to use the export block to export a .csv file with the string returned by the QR code scanner and the data collected by the sensor, for example, the temperature of ABC001 is 30°C. It seems that the export block does not support exporting non-numeric data. Is there another method to achieve this? Thank you.image
