<operator name="Root" class="Process" expanded="yes"> <operator name="FileIterator" class="FileIterator" expanded="yes"> <parameter key="directory" value="c:\data"/> <operator name="CSVExampleSource" class="CSVExampleSource"> <parameter key="filename" value="%{file_name}"/> <parameter key="label_name" value="label"/> </operator> <operator name="ParameterIteration" class="ParameterIteration" expanded="yes"> <list key="parameters"> <parameter key="OperatorSelector.select_which" value="[1.0;3.0;3;linear]"/> </list> <operator name="XValidation" class="XValidation" expanded="no"> <operator name="OperatorSelector" class="OperatorSelector" expanded="no"> <operator name="DecisionTree" class="DecisionTree"> </operator> <operator name="NaiveBayes" class="NaiveBayes"> </operator> <operator name="JMySVMLearner" class="JMySVMLearner"> </operator> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="Performance" class="Performance"> </operator> </operator> </operator> <operator name="ProcessLog" class="ProcessLog"> <list key="log"> <parameter key="File" value="operator.CSVExampleSource.parameter.filename"/> <parameter key="Learner" value="operator.OperatorSelector.parameter.select_which"/> <parameter key="Performance" value="operator.XValidation.value.performance"/> <parameter key="Deviation" value="operator.XValidation.value.deviation"/> </list> </operator> </operator> </operator></operator>
