Merge classes iteratively and perform a one vs all classification. During scoring aggregate the confidence-values from the different models (e.g. maximum, use the operator AttributeConstruction for that strategy)
For each category I have close to 100 examples. BTW, what is the ideal number of examples? I'm only working on the abstract section of the documents.
But is it possible to do hierarchical categorization in RapidMiner?
Last question: What exactly does the "attribute weight" do? From what I understand, you apply the attribute weight to an exampleset to change the values of the attributes. What else is it use for?
PS: I have got the slight feeling that you are missing some data mining basics. I suggest this book. RapidMiner is a tool for the application to a science, so it is better to learn the science first and the tool afterwards. No offense
Sebastian Land wrote:you won't believe but we are working on a book...
