insufficient memory problem
m_r_nour
hi all
I have a data base with 4375 record and 57 features and I want to use LOF (local outlier factor) to remove outliers.
but I have insufficient memory problem
I'd appreciate if you help me how can I solve this problem
Regards
REZA
land
if you take a look at the memory monitor, how many MB of RAM are available?
Greetings,
Sebastian
m_r_nour
hi
just 63mb in Rapidminer while I have 4Gb ram
fischer
How are you starting RapidMiner? Using the .exe, this should not happen. If you run it by invoking java directly, you will have to set the heap size using the java -Xm switch. You can see how this is done if you look at the start scripts in the scripts folder. You can edit the MAX_JAVA_MEMORY variable there.
Best,
Simon
