How to get attached elem list for a given elem id in hyperview using tcl command?
please, take a look at the "SelectionSet Add" command.
First you add a particular element, and then you add again, by using the 'attached' option.
There is an example in the documentation of this command, as you can see below.
Adds entities to the selection set.
selectionSet_handle Add <PoolName> selection
If the <PoolName> is not specified, then the User_Set pool is considered the default.
HyperView Tcl Modify
This command adds entities specified by the argument selection to the current selection set (for example, Add "id 1", Add "id = 1").
In addition to these rules, a Reverse rule can be used for appropriate entities which will reverse the current selection in the set. Please follow its usage in the example.
hwi OpenStack hwi GetSessionHandle session_handle session_handle GetProjectHandle project_handle project_handle GetPageHandle page_handle [project_handle GetActivePage] page_handle GetWindowHandle window_handle [page_handle GetActiveWindow] window_handle GetClientHandle client_handle client_handle GetModelHandle model_handle [client_handle GetActiveModel] model_handle GetSelectionSetHandle selection_set_handle [model_handle AddSelectionSet node] selection_set_handle SetLabel "OurNodeSelectionSet" puts "Possible list selections: [selection_set_handle GetSelectByList]" selection_set_handle Clear selection_set_handle Add all puts "Add all : [selection_set_handle GetSize] [selection_set_handle GetType]s" #add node with a particular ID selection_set_handle Clear selection_set_handle Add "id 1" #if your model has different pools use the following command #and replace poolName with your pool name #set poolName "MyPoolName"; selection_set_handle Add "$poolName id 1" puts "Add id 1 : [selection_set_handle GetSize] [selection_set_handle GetType]s" #add nodes in the ID range of 1 to 100 selection_set_handle Clear selection_set_handle Add "id 1-100" #add nodes in the ID range of 101 to 200 and 205 to 300 from poolName set poolName "MyPoolName"; selection_set_handle Add "$poolname idlist 101-200, 205-300" puts "Add id 1-100 : [selection_set_handle GetSize] [selection_set_handle GetType]s" #add all nodes in the specified component-ID range (1-100) #add assembly uses the same syntax as add component selection_set_handle Clear selection_set_handle Add "component 1-100" puts "Add component 1-100 : [selection_set_handle GetSize] [selection_set_handle GetType]s" #add all nodes on the specified component, #replace compName by your component name set compName component1 selection_set_handle Clear selection_set_handle Add "component == $compName" puts "Add nodes on component $compName : [selection_set_handle GetSize] [selection_set_handle GetType]s" #add all nodes with a contour value above 0.0 selection_set_handle Clear selection_set_handle Add "contour > 0.0" puts "Add contour value above 0 : [selection_set_handle GetSize] [selection_set_handle GetType]s" #add entities from another selectionset of a given poolName selection_set_handle Clear model_handle GetSelectionSetHandle selection_set_handle2 [model_handle AddSelectionSet node]; selection_set_handle2 Add "id 1-100" selection_set_handle Add "<poolName> selectionset == [selection_set_handle2 GetID] " #if <poolName> is not specified, then the selection will be done from the User_set pool as default puts "Add another selection set : [selection_set_handle GetSize] [selection_set_handle GetType]s" selection_set_handle2 ReleaseHandle #add all nodes inside a defined sphere selection_set_handle Clear set x 247.5; set y 327.1; set z 574.5; set radius 1.2 selection_set_handle Add "sphere $x $y $z $radius" puts "Add nodes in defined shpere : [selection_set_handle GetSize] [selection_set_handle GetType]s" #add all nodes adjacent to the current selection selection_set_handle Clear selection_set_handle Add "id 1 " puts "Add node with id 1 : [selection_set_handle GetSize] [selection_set_handle GetType]s" selection_set_handle Add "adjacent" puts "Add all adjacent nodes : [selection_set_handle GetSize] [selection_set_handle GetType]s" #add all nodes attached to the current selection selection_set_handle Clear selection_set_handle Add "id 1 " puts "Add node with id 1 : [selection_set_handle GetSize] [selection_set_handle GetType]s" selection_set_handle Add "attached" puts "Add all attached nodes : [selection_set_handle GetSize] [selection_set_handle GetType]s" #add all nodes attached to elements of the defined dimension #examples for dimension: 1(beams,bars), 2(shells),3(solids), 0(mass elements) selection_set_handle Clear selection_set_handle Add "dimension 2" puts "Add nodes attached to 2D elements : [selection_set_handle GetSize] [selection_set_handle GetType]s" #to find the top 10 or bottom 10 entities from the contour plot selection_set_handle Clear selection_set_handle Add "contour top 10" selection_set_handle Add "contour bottom 10" #to find entities with contour values greater than or less than certain values selection_set_handle Add "contour > 50" selection_set_handle Add "contour < 0.5" #to find entity with maximum and minimum contour value from the given entity set under poolName set poolName "MyPoolName"; selection_set_handle Add "$poolname contour maxofset <set_id>" selection_set_handle Add "$poolname contour minofset <set_id>" # Add entities intersecting a plane whose normal is X-axis and the base point is -642, 23, -339 with a tolerance value of 1.0 selection_set_handle Add "plane 1.0 x -642 23 -339" # Select entities by face # This command assumes there is atleast one entity already existing in the set selection_set_handle Add “face” # Reverse rule is not a part of Add # You simply call Reverse API on the set handle selection_set_handle Reverse hwi CloseStack
