<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <parameter key="logfile" value="C:\Dokumente und Einstellungen\cniemann\Eigene Dateien\bla.log"/> <parameter key="resultfile" value="C:\Dokumente und Einstellungen\cniemann\Eigene Dateien\blub.res"/> <process expanded="true" height="521" width="681"> <operator activated="true" class="retrieve" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75"> <parameter key="repository_entry" value="first data"/> </operator> <operator activated="true" class="nominal_to_text" expanded="true" height="76" name="Nominal to Text" width="90" x="179" y="120"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attributes" value="Text"/> </operator> <operator activated="true" class="select_attributes" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="120"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="Text"/> </operator> <operator activated="true" class="text:process_document_from_data" expanded="true" height="76" name="Process Documents from Data" width="90" x="447" y="165"> <list key="specify_weights"/> <process expanded="true" height="623" width="710"> <operator activated="true" class="text:tokenize" expanded="true" height="60" name="Tokenize" width="90" x="306" y="197"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="word list" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="442" width="948"> <operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="75"> <list key="function_descriptions"/> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="380" y="75"> <parameter key="name" value="label"/> <parameter key="target_role" value="label"/> </operator> <connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <parameter key="logfile" value="C:\Dokumente und Einstellungen\cniemann\Eigene Dateien\bla.log"/> <parameter key="resultfile" value="C:\Dokumente und Einstellungen\cniemann\Eigene Dateien\blub.res"/> <process expanded="true" height="521" width="748"> <operator activated="true" class="text:create_document" expanded="true" height="60" name="Create Document" width="90" x="45" y="30"> <parameter key="text" value="Hi, in the new TextProcessing Extension of RapidMiner 5.0 there you will be able to visualize the word list with the values of occurrences with the rich selection of plotters available in RapidMiner. If you want to see the source document of a word vector, you might use the TextExampleVisualizer. Whereever you click on an example in the plotter, you will see the original text. Greetings, Sebastian"/> <parameter key="add label" value="true"/> <parameter key="label_value" value="label"/> </operator> <operator activated="true" class="text:create_document" expanded="true" height="60" name="Create Document (2)" width="90" x="45" y="120"> <parameter key="text" value="Hi, Using other Text Mining operators i got TFIDF.Is there any other RM operators to graphically represent the words and its TFIDF. Thanks Maria"/> <parameter key="add label" value="true"/> <parameter key="label_value" value="label"/> </operator> <operator activated="true" class="text:documents_to_data" expanded="true" height="94" name="Documents to Data" width="90" x="313" y="30"> <parameter key="text_attribute" value="text"/> <parameter key="label_attribute" value="labelAttribute"/> </operator> <operator activated="true" class="text:process_document_from_data" expanded="true" height="76" name="Process Documents from Data" width="90" x="447" y="30"> <list key="specify_weights"/> <process expanded="true" height="623" width="710"> <operator activated="true" class="text:tokenize" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/> <connect from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="text:wordlist_to_data" expanded="true" height="76" name="WordList to Data" width="90" x="581" y="30"/> <connect from_op="Create Document" from_port="output" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Create Document (2)" from_port="output" to_op="Documents to Data" to_port="documents 2"/> <connect from_op="Documents to Data" from_port="example set" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="word list" to_op="WordList to Data" to_port="word list"/> <connect from_op="WordList to Data" from_port="word list" to_port="result 1"/> <connect from_op="WordList to Data" from_port="example set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
<operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="442" width="948"> <operator activated="true" class="generate_attributes" expanded="true" height="76" name="Generate Attributes" width="90" x="246" y="75"> <list key="function_descriptions"> <parameter key="label" value=""any string value""/> </list> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="380" y="75"> <parameter key="name" value="label"/> <parameter key="target_role" value="label"/> </operator> <connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> </process> </operator>
