<operator name="Root" class="Process" expanded="yes"> <description text="This process plots the learning curve, i.e. the performance with respect to the number of examples which is used for learning."/> <parameter key="logverbosity" value="warning"/> <parameter key="random_seed" value="2004"/> <operator name="TextInput" class="TextInput" expanded="yes"> <list key="texts"> <parameter key="graphics" value="C:\Dokumente und Einstellungen\sland\Eigene Dateien\Yale\Workspace 4.5\sample\data\newsGroupTexts\graphics"/> <parameter key="hardware" value="C:\Dokumente und Einstellungen\sland\Eigene Dateien\Yale\Workspace 4.5\sample\data\newsGroupTexts\hardware"/> </list> <parameter key="output_word_list" value="resultWordlist.wordlist"/> <list key="namespaces"> </list> <operator name="StringTokenizer" class="StringTokenizer"> </operator> </operator> <operator name="CSVExampleSource" class="CSVExampleSource"> <parameter key="filename" value="resultWordlist.wordlist"/> <parameter key="read_attribute_names" value="false"/> <parameter key="comment_chars" value="@/> <parameter key="use_quotes" value="false"/> </operator> <operator name="ExampleFilter" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="resultWordlist.wordlist (1)=Path|club"/> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <operator name="AttributeFilter" class="AttributeFilter"> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="parameter_string" value="att1|att2|att.*"/> </operator></operator>
