Is there a way to define in INSPIRE relative displacement between two points as an optimization constraint?
To be precise, I am interested in giving constraint to relative displacement only in a certain direction.
Thanks in advance
Yosef
Hello Yosef,
Could you provide us an example of what you want to do ? (picture)
Br-
Thomas
Hello Yosef, Could you provide us an example of what you want to do ? (picture) Br- Thomas
Hello Thomas,
I want to use such a constraint as workaround to prevent torsion in bending the beam, when the load is not symmetrical.
Hello Thomas, I want to use such a constraint as workaround to prevent torsion in bending the beam, when the load is not symmetrical. Yosef
Did you try with this ?
This constraint does not meet the need because it is an absolute constraint. I need relative constraint.
This constraint does not meet the need because it is an absolute constraint. I need relative constraint. Yosef
That was my concern also. Thus it's not possible to do it Inspire, but you can do it with OptiStruct using DRESP2 card.
BR-
