I'm currently playing around with the Value Series plugin. I want to plot on a single graph the real values of my series, as well as the predicted values. To do this, the SeriesPrediction operator seemed adequate. However, I have trouble setting it up correctly. From what I understood of its description, it should take as inner operator a Learner, like in the following process:
<parameter key="logverbosity" value="error"/>
<operator name="GenerateSinusLikeSeries" class="OperatorChain" expanded="no">
<operator name="ExampleSetGenerator" class="ExampleSetGenerator">
<parameter key="target_function" value="simple sinus"/>
<parameter key="number_of_attributes" value="1"/>
<operator name="Sorting" class="Sorting">
<parameter key="attribute_name" value="att1"/>
<operator name="AttributeFilter" class="AttributeFilter">
<parameter key="condition_class" value="attribute_name_filter"/>
<parameter key="parameter_string" value="label"/>
<operator name="SeriesPrediction" class="SeriesPrediction" expanded="yes">
<parameter key="horizon" value="2"/>
<operator name="LibSVMLearner" class="LibSVMLearner">
<parameter key="svm_type" value="nu-SVR"/>
<list key="class_weights">
</list>
But this fails with the following error:
Error in: LibSVMLearner (LibSVMLearner) The input example set has less than 2 examples. Some operators need a minimum number of examples. Please check the input files or the experiment setup if this minimum number should be provided by your dataset.
The way I got it to "work" was to use a model as an inner operator, likewise:
<operator name="IOMultiplier" class="IOMultiplier">
<parameter key="io_object" value="ExampleSet"/>
<operator name="ChangeAttributeRole" class="ChangeAttributeRole">
<parameter key="name" value="label"/>
<operator name="Series2WindowExamples" class="Series2WindowExamples">
<parameter key="series_representation" value="encode_series_by_examples"/>
<parameter key="window_size" value="10"/>
</list>
<operator name="IOStorer" class="IOStorer">
<parameter key="name" value="myModel"/>
<parameter key="io_object" value="Model"/>
<operator name="OperatorChain" class="OperatorChain" expanded="yes">
<operator name="IORetriever" class="IORetriever">
<parameter key="remove_from_store" value="false"/>
<operator name="ModelApplier" class="ModelApplier">
<parameter key="keep_model" value="true"/>
<list key="application_parameters">
</list>
However, this technique is in contradiction with the SeriesPrediction's description, and seems a bit complicated!
Soooo, how am I supposed to use this operator in the "right" way? Would you have an example process I could refer to?
Thanks in advance for your help!
- R
