<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="sum"/> <parameter key="number_of_attributes" value="50"/> </operator> <operator name="ChangeAttributeRole" class="ChangeAttributeRole"> <parameter key="name" value="label"/> </operator> <operator name="MultivariateSeries2WindowExamples" class="MultivariateSeries2WindowExamples"> <parameter key="window_size" value="10"/> </operator> <operator name="WindowExamples2ModelingData" class="WindowExamples2ModelingData"> <parameter key="label_name_stem" value="label"/> </operator> <operator name="LinearRegression" class="LinearRegression"> <parameter key="keep_example_set" value="true"/> </operator> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="WindowExamples2OriginalData" class="WindowExamples2OriginalData"> </operator></operator>
