<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="simple non linear classification"/> </operator> <operator name="Count All Examples" class="DataMacroDefinition"> <parameter key="macro" value="Total"/> </operator> <operator name="Change label to more tractable attribute" class="ChangeAttributeRole"> <parameter key="name" value="label"/> </operator> <operator name="Sort examples" class="Sorting"> <parameter key="attribute_name" value="label"/> </operator> <operator name="Take a copy for later" class="IOMultiplier"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="Remove positives" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="label=positive"/> <parameter key="invert_filter" value="true"/> </operator> <operator name="Count Negatives" class="DataMacroDefinition"> <parameter key="macro" value="Neg"/> </operator> <operator name="Calculate Positives" class="MacroConstruction"> <list key="function_descriptions"> <parameter key="Pos" value="%{Total}-%{Neg}"/> </list> <parameter key="use_standard_constants" value="false"/> </operator> <operator name="Compute First & Last deletions" class="MacroConstruction"> <list key="function_descriptions"> <parameter key="First" value="if(%{Neg}>=%{Pos},1,2*%{Neg}+1)"/> <parameter key="Last" value="if(%{Neg}>=%{Pos},%{Total}-2*%{Pos},%{Total})"/> </list> </operator> <operator name="Restore copy, trash other" class="IOSelector"> <parameter key="io_object" value="ExampleSet"/> <parameter key="select_which" value="2"/> <parameter key="delete_others" value="true"/> </operator> <operator name="Filter to equalise" class="ExampleRangeFilter"> <parameter key="first_example" value="%{First}"/> <parameter key="last_example" value="%{Last}"/> <parameter key="invert_filter" value="true"/> </operator> <operator name="Restore label" class="ChangeAttributeRole"> <parameter key="name" value="label"/> </operator></operator>
