Problem with ExampleSet2SeriesObject
User: "Andrew2"
New Altair Community Member
Updated by Jocelyn
Hello all,
I can't get the ExampleSet2SeriesObject operator to work correctly when the transformation_mode is set to series_from_attributes. I get "No value series in input example set!".
Example attached
    <operator name="ExampleSetGenerator" class="ExampleSetGenerator">
        <parameter key="target_function" value="sum"/>
    <operator name="ExampleSet2SeriesObject" class="ExampleSet2SeriesObject">
        <parameter key="transformation_mode" value="series_from_attributes"/>
        <parameter key="series_attribute" value="att1"/>
Should this work?
regards
Andrew
1 - 3 of 31
    User: "land"
    Hi Andrew,
    no this won't work, because in the attribute mode, the series is defined by attributes with the block type "start_series", followed by attributes of block type "series" and then "series_end".
    Since you just generated these attributes, there is no such block type defined. Use SingleToSeries operator to define a series.
    Greetings,
      Sebastian
    User: "Andrew2"
    OP
    Hello Sebastian,
    Thanks for that. Is this sort of detail covered in the various training courses that you offer?
    best regards,
    Andrew
    User: "land"
    beside from giving the basic understanding and explaining the operators of the respective field (and this is indeed a very fundamental operator), individual questions will be answered in the courses. Even shifting the topic a little bit is possible, if all participants agree and wish to hear more details about a special topic.
    Greetings,
      Sebastian
