<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="sum classification"/> </operator> <operator name="IOMultiplier" class="IOMultiplier"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="ExampleFilter" class="ExampleFilter" breakpoints="after"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="label = positive"/> </operator> <operator name="DecisionTree" class="DecisionTree"> </operator> <operator name="ExampleFilter (2)" class="ExampleFilter" breakpoints="after"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="label = negative"/> </operator> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="ClassificationPerformance" class="ClassificationPerformance"> <parameter key="accuracy" value="true"/> <list key="class_weights"> </list> </operator></operator>
