I have built an operator chain to compare a test document to a collection of documents in order to find the most similar documents to the test document. My original apporach did a similarity test across all documents (the collection and the test document) and filtered out just the results for the test document. Needless to say this resulted in comparing all of the collection against itself and was thus inefficient. I have since then tried the approach recommended at the end of this thread:
http://rapid-i.com/rapidforum/index.php/topic,680.msg2587.html#msg2587. Unfortunately I am afraid I have produced a fairly inefficient solution. Could you look at the chain below and give me some advise to improve it?
A couple of considerations:
- I do the text input processing against the collection and the test document so that I have a consistent vocabulary for the similarity processing.
- I get a text file in the log but would prefer an excel or CSV output. Perhaps I can do this in the ProcessLog with some constants for quotation marks and commas.
Here is my chain:
<?xml version="1.0" encoding="windows-1252"?>
<process version="4.5">
<description text=""/>
<operator name="TextInput" class="TextInput" expanded="yes">
<list key="texts">
<parameter key="Past Performance" value="C:\Documents and Settings\xxxx\Desktop\Mining\PP"/>
<parameter key="RFP" value="C:\Documents and Settings\xxxx\Desktop\Mining\RFP"/>
</list>
<parameter key="default_content_type" value=""/>
<parameter key="default_content_encoding" value=""/>
<parameter key="default_content_language" value=""/>
<parameter key="prune_below" value="3"/>
<parameter key="prune_above" value="90"/>
<parameter key="vector_creation" value="TFIDF"/>
<parameter key="use_content_attributes" value="false"/>
<parameter key="use_given_word_list" value="false"/>
<parameter key="return_word_list" value="false"/>
<parameter key="id_attribute_type" value="short"/>
<list key="namespaces">
</list>
<parameter key="create_text_visualizer" value="true"/>
<parameter key="on_the_fly_pruning" value="-1"/>
<parameter key="extend_exampleset" value="false"/>
<operator name="StringTokenizer" class="StringTokenizer">
<operator name="EnglishStopwordFilter" class="EnglishStopwordFilter">
<operator name="TokenLengthFilter" class="TokenLengthFilter">
<parameter key="min_chars" value="3"/>
<parameter key="max_chars" value="2147483647"/>
<operator name="PorterStemmer" class="PorterStemmer">
<operator name="TermNGramGenerator" class="TermNGramGenerator">
<parameter key="max_length" value="2"/>
<operator name="Push PP and RFP" class="IOMultiplier">
<parameter key="number_of_copies" value="1"/>
<parameter key="io_object" value="ExampleSet"/>
<parameter key="multiply_type" value="multiply_one"/>
<parameter key="multiply_which" value="1"/>
<operator name="Get the RFP" class="ExampleFilter">
<parameter key="condition_class" value="attribute_value_filter"/>
<parameter key="parameter_string" value="label = RFP"/>
<parameter key="invert_filter" value="false"/>
<operator name="Store the RFP" class="IOStorer">
<parameter key="name" value="RFP"/>
<parameter key="store_which" value="1"/>
<parameter key="remove_from_process" value="true"/>
<operator name="Get the PP Docs" class="ExampleFilter">
<parameter key="invert_filter" value="true"/>
<operator name="DataMacroDefinition" class="DataMacroDefinition">
<parameter key="macro" value="NumXmp"/>
<parameter key="macro_type" value="number_of_examples"/>
<parameter key="statistics" value="average"/>
<operator name="Store the PP Docs" class="IOStorer">
<parameter key="name" value="PP"/>
<operator name="IteratingOperatorChain" class="IteratingOperatorChain" expanded="yes">
<parameter key="iterations" value="%{NumXmp}"/>
<parameter key="timeout" value="-1"/>
<operator name="Get All PP" class="IORetriever">
<parameter key="remove_from_store" value="false"/>
<operator name="Filter to Current PP" class="ExampleRangeFilter">
<parameter key="first_example" value="%{a}"/>
<parameter key="last_example" value="%{a}"/>
<operator name="Get RFP" class="IORetriever">
<operator name="Combine PP and RFP" class="ExampleSetMerge">
<parameter key="merge_type" value="first_two"/>
<parameter key="datamanagement" value="double_array"/>
<operator name="ExampleSet2Similarity" class="ExampleSet2Similarity">
<parameter key="keep_example_set" value="true"/>
<parameter key="measure_types" value="NumericalMeasures"/>
<parameter key="mixed_measure" value="MixedEuclideanDistance"/>
<parameter key="nominal_measure" value="NominalDistance"/>
<parameter key="numerical_measure" value="CosineSimilarity"/>
<parameter key="divergence" value="GeneralizedIDivergence"/>
<parameter key="kernel_type" value="radial"/>
<parameter key="kernel_gamma" value="1.0"/>
<parameter key="kernel_sigma1" value="1.0"/>
<parameter key="kernel_sigma2" value="0.0"/>
<parameter key="kernel_sigma3" value="2.0"/>
<parameter key="kernel_degree" value="3.0"/>
<parameter key="kernel_shift" value="1.0"/>
<parameter key="kernel_a" value="1.0"/>
<parameter key="kernel_b" value="0.0"/>
<operator name="Similarity2ExampleSet" class="Similarity2ExampleSet">
<parameter key="table_type" value="long_table"/>
<operator name="Get ID" class="Data2Log">
<parameter key="attribute_name" value="SECOND_ID"/>
<parameter key="example_index" value="1"/>
<operator name="Get Similarity" class="Data2Log">
<parameter key="attribute_name" value="SIMILARITY"/>
<parameter key="example_index" value="2"/>
<operator name="ProcessLog" class="ProcessLog">
<parameter key="filename" value="C:\Documents and Settings\xxxx\Desktop\test.log"/>
<list key="log">
<parameter key="ID" value="operator.Get ID.value.data_value"/>
<parameter key="Similarity" value="operator.Get Similarity.value.data_value"/>
</list>
<parameter key="sorting_type" value="none"/>
<parameter key="sorting_k" value="100"/>
<parameter key="persistent" value="true"/>
<operator name="Get rid of current example set" class="IOConsumer">
<parameter key="deletion_type" value="delete_one"/>
<parameter key="delete_which" value="1"/>
<parameter key="except" value="1"/>
</process>
I thank you very much in advance for your thoughts and recommendations.
Charles
