Bug Report, WEKA:Naive Bayes
Rapidminer 4.5
Dear All,
I hope this is a correct bug report.
I wasn't sure where to post.
The WEKA Naive Bayes refuses to run:
it claim's ComplementNaiveBayes: Cannot handle multi-valued nominal attributes!
But I think it should use weka.classifiers.bayes.NaiveBayes, not ComplementNaiveBayes!
I used the following data, and loaded it inside WEKA to confirm that NaiveBayes runs fine there.
Data:
"Day";"Outlook";"Temperature";"Humidity";"Wind";"PlayTennis"
"Dl";"Sunny";"Hot";"High";"Weak";"No"
"D2";"Sunny";"Hot";"High";"Strong";"No"
"D3";"Overcast";"Hot";"High";"Weak";"Yes"
"D4";"Rain";"Mild";"High";"Weak";"Yes"
"D5";"Rain";"Cool";"Normal";"Weak";"Yes"
"D6";"Rain";"Cool";"Normal";"Strong";"No"
"D7";"Overcast";"Cool";"Normal";"Strong";"Yes"
"D8";"Sunny";"Mild";"High";"Weak";"No"
"D9";"Sunny";"Cool";"Normal";"Weak";"Yes"
"Dl0";"Rain";"Mild";"Normal";"Weak";"Yes"
"Dl1";"Sunny";"Mild";"Normal";"Strong";"Yes"
"Dl2";"Overcast";"Mild";"High";"Strong";"Yes"
"Dl3";"Overcast";"Hot";"Normal";"Weak";"Yes"
"Dl4";"Rain";"Mild";"High";"Strong";"No"
Error Log:
P Sep 5, 2009 2:44:06 PM: Initialising process setup
P Sep 5, 2009 2:44:06 PM: [NOTE] No filename given for result file, using stdout for logging results!
P Sep 5, 2009 2:44:06 PM: Checking properties...
P Sep 5, 2009 2:44:06 PM: Properties are ok.
P Sep 5, 2009 2:44:06 PM: Checking process setup...
P Sep 5, 2009 2:44:06 PM: Inner operators are ok.
P Sep 5, 2009 2:44:06 PM: Checking i/o classes...
P Sep 5, 2009 2:44:06 PM: i/o classes are ok. Process output: Model.
P Sep 5, 2009 2:44:06 PM: Process ok.
P Sep 5, 2009 2:44:06 PM: [Warning] W-NaiveBayes: W-NaiveBayes: Deprecated: please use NaiveBayes instead.
P Sep 5, 2009 2:44:06 PM: [Warning] Deprecations: 1 usage of deprecated operators.
P Sep 5, 2009 2:44:06 PM: Process initialised
P Sep 5, 2009 2:44:06 PM: [NOTE] Process starts
P Sep 5, 2009 2:44:06 PM: Process:
Root[1] (Process)
+- CSVExampleSource[1] (CSVExampleSource)
+- W-NaiveBayes[1] (W-NaiveBayes)
P Sep 5, 2009 2:44:06 PM: [Warning] W-NaiveBayes: Deprecated: please use NaiveBayes instead.
P Sep 5, 2009 2:44:06 PM: [Warning] W-NaiveBayes: This learning scheme does not have sufficient capabilities for the given data set: polynominal attributes not supported
G Sep 5, 2009 2:44:06 PM: [Fatal] UserError occured in 1st application of W-NaiveBayes (W-NaiveBayes)
G Sep 5, 2009 2:44:06 PM: [Fatal] Process failed: W-NaiveBayes caused an error: weka.classifiers.bayes.ComplementNaiveBayes: Cannot handle multi-valued nominal attributes!
Root[1] (Process)
here ==> +- W-NaiveBayes[1] (W-NaiveBayes)
