🎉Community Raffle - Win $25
Join and Win
Do I have to create a beam cross section after using PBEAML card image?
User: "MOHAMMAD UMAR MAKNOJIYA"
Altair Community Member
Updated by MOHAMMAD UMAR MAKNOJIYA
I am analysing a 1D L section beam under bending load. So for that I'll create a PBEAML card image property and directly input the dimensions of L section. So, do I have to create a beam cross section after that by going into hyperbeam panel and update the property?
1 - 1 of 11
    User: "Adriano Koga_20259"
    New Altair Community Member
    Updated by Adriano Koga_20259
    if you're using the PBEAML you don't need anything else for your model to work.
    The only reason that you would need it is in case you wanted to check visually the beam section.
