Sebastian Land wrote:unfortunately this isn't possible right now. At least not in an elegant or at least reasonable way.
Sebastian Land wrote:But it would be possibel to filter the processlog afterwards. You could transform it to an example set, use the attribute construction for designing an attribute indicating if the example should be kept and then filter the exampleset accordingly. Perhabs this already solves your needs?
