"Bug - Using RapidMiner from Java-Application"
when calling RapidMiner from Java I tried to use the init-Method from the RapidMiner.java:
RapidMiner.java, Line 207:
public static void init(InputStream operatorsXMLStream,
File pluginDir,
boolean addWekaOperators,
boolean searchJDBCInLibDir,
boolean searchJDBCInClasspath,
boolean addPlugins) {
init(operatorsXMLStream, null, pluginDir, addWekaOperators, searchJDBCInLibDir, searchJDBCInClasspath, addPlugins);
I noticed that this should read:
init(operatorsXMLStream, pluginDir, null, addWekaOperators, searchJDBCInLibDir, searchJDBCInClasspath, addPlugins);
I'm still working with RM 4.4 so perhaps you already fixed this bug.
Greetings,
Daniel
