Consider the output of the below process file,
<operator name="SingleTextObjectInput" class="SingleTextObjectInput">
<parameter key="text" value="The Outputs are in Results Folder."/>
<parameter key="label" value="Trial"/>
The output is the textobject. My questions are:
1. Can I change the font (size, bold etc) of the text, "The Outputs are in 'Results' folder?
2. Can I delete the text "TextObject" and "Label: Trial"?
Dont know if (2) is possible, but if (1) is possible, that should be fine.
Thanks,
Shubha
