<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="sum classification"/> <parameter key="number_examples" value="500"/> </operator> <operator name="MultivariateSeries2WindowExamples" class="MultivariateSeries2WindowExamples"> <parameter key="horizon" value="1"/> <parameter key="window_size" value="5"/> <parameter key="label_attribute" value="att1"/> </operator> <operator name="IOStorer (2)" class="IOStorer"> <parameter key="name" value="ExampleSet"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="IOConsumer" class="IOConsumer"> </operator> <operator name="ParameterIteration" class="ParameterIteration" expanded="yes"> <list key="parameters"> <parameter key="AttributeSubsetPreprocessing.attribute_name_regex" value="att1.*|label,att2.*|label,att3.*|label,att4.*|label,att5.*|label"/> </list> <operator name="IORetriever" class="IORetriever"> <parameter key="name" value="ExampleSet"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="no"> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="attribute_name_regex" value="att5.*|label"/> <parameter key="process_special_attributes" value="true"/> <operator name="ChangeAttributeRole" class="ChangeAttributeRole"> <parameter key="name" value="label"/> <parameter key="target_role" value="label"/> </operator> <operator name="FeatureSelection" class="FeatureSelection" expanded="yes"> <operator name="CFSFeatureSetEvaluator" class="CFSFeatureSetEvaluator"> </operator> </operator> </operator> <operator name="IOStorer" class="IOStorer"> <parameter key="name" value="ExampleSet"/> <parameter key="io_object" value="ExampleSet"/> </operator> </operator> <operator name="IORetriever (2)" class="IORetriever"> <parameter key="name" value="ExampleSet"/> <parameter key="io_object" value="ExampleSet"/> </operator></operator>
