<operator name="Root" class="Process" expanded="yes"> <operator name="CSVExampleSource" class="CSVExampleSource"> <parameter key="filename" value="C:\Dokumente und Einstellungen\sland\Desktop\test.txt"/> <parameter key="read_attribute_names" value="false"/> <parameter key="column_separators" value="This text never occures in the file --- sdhaksj dhaskljdh alkdjsh sa"/> <parameter key="use_comment_characters" value="false"/> </operator> <operator name="Nominal2String" class="Nominal2String"> </operator> <operator name="StringTextInput" class="StringTextInput" expanded="yes"> <list key="namespaces"> </list> </operator></operator>
