I am trying to run a simulation of impact on a composite plate. I am using solid elements for the plies. For the material model, I am using law25 (COMPSH) with property 6 (SOL_ORTH). However, when I run little tensile tests on a single element, I can't seem to find the right modulus.
Here are the material data I used :
## Material Law No 25. COMPOSITE SHELL
/MAT/COMPSH/1
composite
1.58000000000000E-06
112.0 8.0 0.28 1 8.0
4.5 2.857 4.5
1.00000000000000E+30
And here are my options used for the property:
## Orthotropic Solid Property Set (pid 6)
/PROP/SOL_ORTH/1
composite
24 2
3
45.0
1
I chose Ip = 3 and i am changing the value of Psi to get the correct orientation.
For Psi = 0 deg or Psi = 90 deg, i get modulus close to E11 and E22. However for Psi = 45 deg and Psi = -45 deg, i get 2 different modulus and they are not close to the shear modulus i entered.
Can anyone help me with this issue ?
Thanks in advance,
Maxime
