Hi guys,
I've been tasked with creating a model on a training set, then applying it to a test set. In order to do this, I have this setup in the GUI: (Sorry about the bad names, just know I am loading the test set at the end!)
It's giving me problems.
a) I don't think saving the model every iteration, then loading it again at the end, is a good thing. It takes a fair chunk of time to write the model out each time. How can I refer back to it? This is particularly bad if I am running feature selection. I have to manually filter out the attributes the feature selecter chose when I load the test set.
b) Putting the boosting in there results in errors. Without the boosting, this works to completion. The errors I get are:
P Jun 3, 2009 9:56:54 PM: [Warning] AdaBoost: The number of nominal values is not the same for training and application for attribute 'state1', training: 53, application: 52
P Jun 3, 2009 9:56:54 PM: [Warning] AdaBoost: The number of nominal values is not the same for training and application for attribute 'domain1', training: 9809, application: 4695
G Jun 3, 2009 9:56:54 PM: [Warning] Distribution: The number of nominal values is not the same for training and application for attribute 'state1', training: 53, application: 52
G Jun 3, 2009 9:56:54 PM: [Warning] Distribution: The number of nominal values is not the same for training and application for attribute 'domain1', training: 9809, application: 4695
G Jun 3, 2009 9:56:55 PM: [Warning] Distribution: The number of nominal values is not the same for training and application for attribute 'state1', training: 53, application: 52
G Jun 3, 2009 9:56:55 PM: [Warning] Distribution: The number of nominal values is not the same for training and application for attribute 'domain1', training: 9809, application: 4695
G Jun 3, 2009 9:56:56 PM: [Warning] Distribution: The number of nominal values is not the same for training and application for attribute 'domain1', training: 9809, application: 4695
G Jun 3, 2009 9:56:56 PM: [Warning] Distribution: The number of nominal values is not the same for training and application for attribute 'state1', training: 53, application: 52
G Jun 3, 2009 9:56:57 PM: [Fatal] NullPointerException occured in 1st application of ModelApplier (2) (ModelApplier)
G Jun 3, 2009 9:56:57 PM: [Fatal] Process failed: operator cannot be executed. Check the log messages...
It's the NullPointerException that kills it, but I don't know what it's referring to. As I said, removing the boosting, it works fine. Any ideas?
Thanks guys!
