I am trying to measure Neural Networks Performance as training cycles increase. I need to plot cycles vs performance.The problem is the performance values is the same in all training cycles !!!!! ??? :-\ . are there some thing wrong with my code?
<operator name="ArffExampleSource" class="ArffExampleSource" breakpoints="after">
<parameter key="data_file" value="D:\Users\Motaz\Documents\rm_workspace\sample\weka-data\cpu.arff"/>
<parameter key="label_attribute" value="class"/>
<operator name="ParameterIteration" class="ParameterIteration" expanded="yes">
<list key="parameters">
<parameter key="NeuralNet.training_cycles" value="50,75,100,150,200,300,400,500,600,700,800,900,1000"/>
</list>
<operator name="NeuralNet" class="NeuralNet">
<parameter key="keep_example_set" value="true"/>
<list key="hidden_layer_types">
<parameter key="sigmoid" value="5"/>
</list>
<parameter key="learning_rate" value="0.3"/>
<operator name="ModelApplier" class="ModelApplier">
<parameter key="keep_model" value="true"/>
<list key="application_parameters">
</list>
<operator name="RegressionPerformance" class="RegressionPerformance">
<parameter key="relative_error" value="true"/>
<operator name="ProcessLog" class="ProcessLog">
<list key="log">
<parameter key="cycles" value="operator.NeuralNet.parameter.training_cycles"/>
<parameter key="performance" value="operator.RegressionPerformance.parameter.relative_error"/>
</list>
Thanks,
Motaz
