I run the below code,
<operator name="ExampleSetGenerator (3)" class="ExampleSetGenerator">
<parameter key="target_function" value="spiral cluster"/>
<parameter key="number_of_attributes" value="2"/>
<operator name="ExampleSetGenerator" class="ExampleSetGenerator">
<parameter key="target_function" value="random"/>
<parameter key="number_examples" value="1"/>
<parameter key="number_of_attributes" value="1"/>
<operator name="Real2Integer" class="Real2Integer">
<parameter key="round" value="true"/>
<operator name="AttributeConstruction" class="AttributeConstruction">
<parameter key="store" value="abs(att1)"/>
</list>
<operator name="DataMacroDefinition" class="DataMacroDefinition">
<parameter key="macro" value="k_val"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="attribute_name" value="store"/>
<parameter key="example_index" value="1"/>
<operator name="IOSelector" class="IOSelector">
<parameter key="io_object" value="ExampleSet"/>
<parameter key="select_which" value="2"/>
<operator name="LOFOutlierDetection (2)" class="LOFOutlierDetection">
<parameter key="minimal_points_lower_bound" value="%{k_val}"/>
<parameter key="minimal_points_upper_bound" value="%{k_val}"/>
And get the error,
[quote]
Process Failed:
NumberFormatException caught: For input string: "4.0"[/quote]
Why is this error? The data read is an integer. But still the error comes.... Any ideas?
Thanks, Shubha
