IndexOutOfBoundsException caught null
I am new on this tool. I tryed to start a process in the GUI. This is to read in only a SPSSExampleSource file. With the process start immediately an error comes. ???
G Apr 28, 2009 8:42:16 PM: [Fatal] IndexOutOfBoundsException occured in 1st application of SPSSExampleSource (SPSSExampleSource)
G Apr 28, 2009 8:42:16 PM: [Fatal] Process failed: operator cannot be executed. Check the log messages...
Root[1] (Process)
here ==> +- SPSSExampleSource[1] (SPSSExampleSource)
This is from the Logfile
P Apr 28, 2009 8:39:26 PM: Logging: log file is 'test.log'...
P Apr 28, 2009 8:39:26 PM: Initialising process setup
P Apr 28, 2009 8:39:26 PM: [NOTE] No filename given for result file, using stdout for logging results!
P Apr 28, 2009 8:39:26 PM: Checking properties...
P Apr 28, 2009 8:39:26 PM: Properties are ok.
P Apr 28, 2009 8:39:26 PM: Checking process setup...
P Apr 28, 2009 8:39:26 PM: Inner operators are ok.
P Apr 28, 2009 8:39:26 PM: Checking i/o classes...
P Apr 28, 2009 8:39:26 PM: i/o classes are ok. Process output: ExampleSet.
P Apr 28, 2009 8:39:26 PM: Process ok.
P Apr 28, 2009 8:39:26 PM: Process initialised
P Apr 28, 2009 8:39:26 PM: [NOTE] Process starts
P Apr 28, 2009 8:39:26 PM: Process:
Root[1] (Process)
thanks for help.
dan
