I can use IOObjectWriter and ResultWriter to write the results of an AverageBuilder to a file when I run the setup from the GUI. But when I run it from the command line, it fails with:
G Apr 28, 2009 10:24:09 AM: [Fatal] NullPointerException occured in 1st application of IOObjectWriter (IOObjectWriter)
G Apr 28, 2009 10:24:09 AM: [Fatal] Process failed: operator cannot be executed. Check the log messages...
The rest of the file works fine; just the IOObjectWriter or ResultWriter fails.
How do you write the results of an AverageBuilder to a file from the command line?
Here's the XML of the operators:
<operator name="AverageBuilder" class="AverageBuilder">
<operator name="IOObjectWriter" class="IOObjectWriter">
<parameter key="object_file" value="training_perf_%{t}.txt"/>
<parameter key="io_object" value="AverageVector"/>
<parameter key="output_type" value="XML"/>
I
