Prefixing the Attribute names
Shubha
New Altair Community Member
I want to prefix certain attribute names with a particular string. Below I have a generated an example data....
I tried with changing attribute names and related operators, but did not get it... How do i perform this?
Thanks, Shubha
<operator name="Root" class="Process" expanded="yes">Now in the above data, I need to Prefix the attributes A, B, H, Y and M with the string, "Var_". So, my new changed attribute names are now, Var_A, Var_B, Var_H, Var_Y and Var_M. Note: The original variables A, B, H.... can be a mix of any data type, not always real.
<operator name="Generate Suitable Data" class="OperatorChain" expanded="yes">
<operator name="ExampleSetGenerator" class="ExampleSetGenerator">
<parameter key="target_function" value="sum"/>
<parameter key="number_examples" value="10"/>
<operator name="ChangeAttributeName" class="ChangeAttributeName">
<parameter key="old_name" value="att1"/>
<parameter key="new_name" value="A"/>
<operator name="ChangeAttributeName (2)" class="ChangeAttributeName">
<parameter key="old_name" value="att2"/>
<parameter key="new_name" value="B"/>
<operator name="ChangeAttributeName (3)" class="ChangeAttributeName">
<parameter key="old_name" value="att3"/>
<parameter key="new_name" value="H"/>
<operator name="ChangeAttributeName (4)" class="ChangeAttributeName">
<parameter key="old_name" value="att4"/>
<parameter key="new_name" value="Y"/>
<operator name="ChangeAttributeName (5)" class="ChangeAttributeName">
<parameter key="old_name" value="att5"/>
<parameter key="new_name" value="M"/>
Thanks, Shubha
Hi, got that done by adding the below code:
<operator name="ChangeAttributeNamesReplace" class="ChangeAttributeNamesReplace">
<parameter key="replace_what" value="^"/>
<parameter key="replace_by" value="Var_"/>
</operator>0
