I am using logistic regression with cross validation and I would like to save the predicted label probability and true label for each data point in the set at the end of the process. Is it possible to do this with rapidminer?
Edit: I figured out how to do this by using the XVPrediction operator. My code is below in case anyone runs into the same issue:
<operator name="Root" class="Process" expanded="yes">>
<operator name="ExampleSource" class="ExampleSource">
<parameter key="attributes" value="/home/user/rm_workspace/data.aml"/>
<operator name="XVPrediction" class="XVPrediction" expanded="yes">
<parameter key="number_of_validations" value="2"/>
<operator name="LogisticRegression" class="LogisticRegression">
<parameter key="keep_example_set" value="true"/>
<parameter key="return_model_performance" value="true"/>
<operator name="OperatorChain" class="OperatorChain" expanded="yes">
<operator name="ModelApplier" class="ModelApplier">
<parameter key="keep_model" value="true"/>
<list key="application_parameters">
</list>
<operator name="ExcelExampleSetWriter" class="ExcelExampleSetWriter">
<parameter key="excel_file" value="/home/user/rm_workspace/log.xls"/>
</list>
