Rapidminer causes hanging inside the kernel?
I'm running Rapidminer under Mac OS X 10.5.6, fully updated. After Rapidminer uses almost all its allowed memory, it seems to hang. The top processes running are as foolows. Is this known behavior? How to prevent it?
Processes: 61 total, 3 running, 58 sleeping... 232 threads 09:59:58
Load Avg: 2.90, 2.50, 2.34 CPU usage: 35.44% user, 50.21% sys, 14.35% idle
SharedLibs: num = 7, resident = 28M code, 692K data, 1916K linkedit.
MemRegions: num = 5951, resident = 1198M + 10M private, 97M shared.
PhysMem: 354M wired, 1011M active, 531M inactive, 1902M used, 146M free.
VM: 7843M + 374M 144693(23) pageins, 50977(0) pageouts
PID COMMAND %CPU TIME #TH #PRTS #MREGS RPRVT RSHRD RSIZE VSIZE
0 kernel_tas 87.6% 62:26.80 52 2 310 5592K 0 134M 283M
2135 java 52.7% 45:08.10 20 1085 469 1130M+ 15M 1148M+ 1606M
Comments
There are no comments yet
