<operator name="Root" class="Process" expanded="yes"> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="random"/> </operator> <operator name="AttributeSubsetPreprocessing" class="AttributeSubsetPreprocessing" expanded="yes"> <parameter key="condition_class" value="attribute_name_filter"/> <parameter key="attribute_name_regex" value="label"/> <parameter key="process_special_attributes" value="true"/> <parameter key="deliver_inner_results" value="true"/> <operator name="BinDiscretization" class="BinDiscretization"> <parameter key="range_name_type" value="short"/> </operator> </operator> <operator name="IOMultiplier" class="IOMultiplier"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="LibSVMLearner" class="LibSVMLearner"> <parameter key="keep_example_set" value="true"/> <parameter key="kernel_type" value="linear"/> <list key="class_weights"> <parameter key="range1" value="5.0"/> <parameter key="range2" value="1.0"/> </list> </operator> <operator name="ModelApplier" class="ModelApplier"> <parameter key="keep_model" value="true"/> <list key="application_parameters"> </list> </operator> <operator name="ModelWriter" class="ModelWriter"> <parameter key="model_file" value="bla"/> </operator> <operator name="IOSelector" class="IOSelector"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="SVMWeighting" class="SVMWeighting"> <parameter key="normalize_weights" value="false"/> </operator></operator>
