My requirement from the load path is to monitor contact forces over a load path. As per the problem description in the attached picture, I would like to extract contact forces on each part No. 1, 2, 3 when a impactor hits the part 1. I came across a card /INTER/SUB, but the card contents are not clear to understand. Main_ID1, Second_ID, Main_ID2 are the ones with no proper explanation about the definition's and usage. Can someone throw light in this area? If there is any other alternative apart from /INTER/SUB to extract contact forces, that will be great to know.
Looking forward to hear about the response.
