<operator name="Root" class="Process" expanded="yes"> <description text=" "/> <parameter key="logverbosity" value="warning"/> <operator name="Define conclusion to look for" class="SingleMacroDefinition"> <parameter key="macro" value="Look_for"/> <parameter key="value" value="car_practical"/> </operator> <operator name="Generate some data" class="DirectMailingExampleSetGenerator"> </operator> <operator name="Preprocessing" class="OperatorChain" expanded="yes"> <operator name="Make name the ID" class="ChangeAttributeRole"> <parameter key="name" value="name"/> <parameter key="target_role" value="id"/> </operator> <operator name="Association rules, so make label normal attribute" class="ChangeAttributeRole"> <parameter key="name" value="label"/> </operator> <operator name="Put numbers into bins" class="BinDiscretization"> <parameter key="range_name_type" value="short"/> </operator> <operator name="Dichotomise the attributes" class="Nominal2Binominal"> </operator> </operator> <operator name="Make and file away association rules" class="OperatorChain" expanded="yes"> <operator name="Make frequent item sets" class="FPGrowth"> <parameter key="find_min_number_of_itemsets" value="false"/> <parameter key="min_support" value="0.1"/> </operator> <operator name="Make some if then rules" class="AssociationRuleGenerator"> <parameter key="min_confidence" value="0.7"/> </operator> <operator name="File the results as assocs" class="ResultWriter"> <parameter key="result_file" value="assocs"/> </operator> </operator> <operator name="Look for the desired conclusion" class="OperatorChain" expanded="yes"> <operator name="Load the results as 1 attribute examples, line by line" class="SimpleExampleSource"> <parameter key="filename" value="assocs"/> <parameter key="column_separators" value="\n"/> </operator> <operator name="Rename attribute assoc (1) to assoc to make it usable" class="ChangeAttributeNamesReplace"> <parameter key="replace_what" value="\s|\(|\)|1"/> <parameter key="apply_on_special" value="false"/> </operator> <operator name="Make example 1 binnable as it only has RM comments" class="SetData"> <parameter key="attribute_name" value="assocs"/> <parameter key="example_index" value="1"/> <parameter key="value" value="x"/> </operator> <operator name="Make example two the attributes header" class="SetData"> <parameter key="attribute_name" value="assocs"/> <parameter key="example_index" value="2"/> <parameter key="value" value="Premises|Conclusions|Confidence"/> </operator> <operator name="Bin example 1" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="assocs=x"/> <parameter key="invert_filter" value="true"/> </operator> <operator name="Mark out Premises, Conclusions, and Confidence columns" class="Replace"> <parameter key="attributes" value=".*"/> <parameter key="replace_what" value="-->|\("/> <parameter key="replace_by" value="|"/> </operator> <operator name="Clear remaining brackets and verbage" class="Replace"> <parameter key="attributes" value=".*"/> <parameter key="replace_what" value="confidence|\[|\]|\)|\:|\s"/> </operator> <operator name="Write out the 1 attribute example set" class="ExampleSetWriter"> <parameter key="example_set_file" value="assocs"/> <parameter key="quote_nominal_values" value="false"/> </operator> <operator name="Read it back as three attribute example set" class="SimpleExampleSource"> <parameter key="filename" value="assocs"/> <parameter key="read_attribute_names" value="true"/> <parameter key="column_separators" value="\|"/> </operator> <operator name="Replace equals sign in Conclusion" class="Replace"> <parameter key="attributes" value="Con.*"/> <parameter key="replace_what" value="="/> <parameter key="replace_by" value="_"/> </operator> <operator name="Remove all conclusions except what is looked for" class="Replace"> <parameter key="attributes" value="Con.*"/> <parameter key="replace_what" value="\b(?:(?!%{Look_for})\w)+\b"/> </operator> <operator name="Remove commas" class="Replace"> <parameter key="attributes" value="Con.*"/> <parameter key="replace_what" value="\,"/> </operator> <operator name="Remove all examples except what is looked for" class="ExampleFilter"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="Conclusions=\?"/> <parameter key="invert_filter" value="true"/> </operator> </operator></operator>
