🎉Community Raffle - Win $25
Join and Win
"Bug in ProcessLog with FeatureSelectionParallel?"
User: "keith"
New Altair Community Member
Updated by Jocelyn
When I try to log the performance (rms error) of a model inside a feature selection process, it only works if I am using the single-threaded FeatureSelection node, not the parallel-processing-enabled FeatureSelectionParallel available in RM Enterprise.
In the two examples below, the ProcessLog in the former produces valid performance data, but the latter has all '?' in the performance column.
    <operator name="ExampleSetGenerator" class="ExampleSetGenerator">
        <parameter key="target_function" value="non linear"/>
        <parameter key="number_examples" value="1000"/>
    <operator name="AttributeConstruction" class="AttributeConstruction">
          <parameter key="att_random1" value="rand()"/>
          <parameter key="att_random2" value="rand()"/>
          <parameter key="att_constant" value="0"/>
        </list>
    <operator name="FeatureSelection" class="FeatureSelection" expanded="yes">
        <parameter key="generations_without_improval" value="2"/>
        <operator name="W-LWL" class="W-LWL">
            <parameter key="keep_example_set" value="true"/>
            <parameter key="K" value="5.0"/>
        <operator name="OperatorChain" class="OperatorChain" expanded="yes">
            <operator name="ModelApplier" class="ModelApplier">
                <list key="application_parameters">
                </list>
            <operator name="RegressionPerformance" class="RegressionPerformance">
                <parameter key="root_mean_squared_error" value="true"/>
            <operator name="ProcessLog" class="ProcessLog">
                <list key="log">
                  <parameter key="generation" value="operator.FeatureSelection.value.generation"/>
                  <parameter key="feature_name" value="operator.FeatureSelection.value.feature_names"/>
                  <parameter key="performance" value="operator.RegressionPerformance.value.root_mean_squared_error"/>
                </list>
        </list>
    <operator name="FeatureSelectionParallel" class="FeatureSelectionParallel" expanded="yes">
                </list>
                <list key="log">
                  <parameter key="generation" value="operator.FeatureSelectionParallel.value.generation"/>
                  <parameter key="feature_name" value="operator.FeatureSelectionParallel.value.feature_names"/>
                </list>
