<operator name="Root" class="Process" expanded="yes"> <parameter key="logverbosity" value="warning"/> <parameter key="random_seed" value="2000"/> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="random dots classification"/> <parameter key="number_examples" value="500"/> <parameter key="number_of_attributes" value="2"/> <parameter key="attributes_lower_bound" value="0.0"/> <parameter key="attributes_upper_bound" value="25.0"/> </operator> <operator name="ROCComparator" class="ROCComparator" expanded="yes"> <operator name="LibSVMLearner" class="LibSVMLearner"> <parameter key="gamma" value="1.0"/> <list key="class_weights"> </list> </operator> <operator name="LinearRegression" class="LinearRegression"> </operator> </operator></operator>
<operator name="Root" class="Process" expanded="yes"> <parameter key="logverbosity" value="warning"/> <parameter key="random_seed" value="2000"/> <operator name="ExampleSetGenerator" class="ExampleSetGenerator"> <parameter key="target_function" value="random dots classification"/> <parameter key="number_examples" value="500"/> <parameter key="number_of_attributes" value="2"/> <parameter key="attributes_lower_bound" value="0.0"/> <parameter key="attributes_upper_bound" value="25.0"/> </operator> <operator name="XValidation" class="XValidation" expanded="no"> <parameter key="keep_example_set" value="true"/> <parameter key="create_complete_model" value="true"/> <parameter key="sampling_type" value="shuffled sampling"/> <operator name="LibSVMLearner" class="LibSVMLearner"> <parameter key="keep_example_set" value="true"/> <parameter key="gamma" value="1.0"/> <list key="class_weights"> </list> </operator> <operator name="OperatorChain" class="OperatorChain" expanded="yes"> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="Performance" class="Performance"> </operator> </operator> </operator> <operator name="ModelWriter" class="ModelWriter"> <parameter key="model_file" value="SVM"/> </operator> <operator name="XValidation (2)" class="XValidation" expanded="no"> <parameter key="keep_example_set" value="true"/> <parameter key="create_complete_model" value="true"/> <parameter key="sampling_type" value="shuffled sampling"/> <operator name="LinearRegression" class="LinearRegression"> </operator> <operator name="OperatorChain (2)" class="OperatorChain" expanded="yes"> <operator name="ModelApplier (2)" class="ModelApplier"> <list key="application_parameters"> </list> </operator> <operator name="Performance (2)" class="Performance"> </operator> </operator> </operator> <operator name="ModelWriter (2)" class="ModelWriter"> <parameter key="model_file" value="LR"/> </operator> <operator name="ROCComparator" class="ROCComparator" expanded="yes"> <operator name="SVM" class="ModelLoader"> <parameter key="model_file" value="SVM"/> </operator> <operator name="LR" class="ModelLoader"> <parameter key="model_file" value="LR"/> </operator> </operator></operator>
