Hello, I am having an astonishing result:
I run a very simple test with nearest neighbors (see xml code below) and I am using a training dataset and an test dataset (see short datasets below).
The seldom result is that I always get the same value for the predicted value, despite the test example I use
If I use the "
ExampleSetGenerator" instead of reading a dataset in a file (activate it in the model I include below) I get a different prediction for every new test example I use, as it is expected.
Can anyone explain what is the reason for getting always the same prediction if I read data from a file?? ???
Any hint or solution will be welcomed!!!!
<operator name="ExampleSource" class="ExampleSource">
<parameter key="attributes" value="/home/miquel/Documents/I+D+I/MICROPREDICCIO/RapidMiner WORKSPACE/PFC 2008-2009/prova_suma.aml"/>
<operator name="ExampleSetGenerator" class="ExampleSetGenerator" activated="no">
<parameter key="number_examples" value="10000"/>
<parameter key="target_function" value="polynomial"/>
<operator name="NearestNeighbors" class="NearestNeighbors">
<operator name="ExampleSource (4)" class="ExampleSource">
<parameter key="attributes" value="/home/miquel/Documents/I+D+I/MICROPREDICCIO/RapidMiner WORKSPACE/PFC 2008-2009/prova_suma_test.aml"/>
<parameter key="permutate" value="true"/>
<operator name="ExampleSetGenerator (2)" class="ExampleSetGenerator" activated="no">
<parameter key="number_examples" value="10"/>
<operator name="ExampleRangeFilter" class="ExampleRangeFilter">
<parameter key="first_example" value="2"/>
<parameter key="last_example" value="2"/>
<operator name="ModelApplier" class="ModelApplier">
<list key="application_parameters">
</list>
<parameter key="create_view" value="true"/>
<parameter key="keep_model" value="true"/>
TRAINING DATA
1 1.6 0.84 0 0.76
2 2.17 0.91 0.3 0.96
3 1.61 0.14 0.48 1
4 0.84 -0.76 0.6 1
5 0.74 -0.96 0.7 1
6 1.5 -0.28 0.78 1
7 2.5 0.66 0.85 1
8 2.89 0.99 0.9 1
9 2.37 0.41 0.95 1
10 1.46 -0.54 1 1
11 1.04 -1 1.04 1
12 1.54 -0.54 1.08 1
13 2.53 0.42 1.11 1
14 3.14 0.99 1.15 1
15 2.83 0.65 1.18 1
16 1.92 -0.29 1.2 1
17 1.27 -0.96 1.23 1
18 1.5 -0.75 1.26 1
19 2.43 0.15 1.28 1
20 3.21 0.91 1.3 1
TEST DATA
21 3.16 0.84 1.32 1
22 2.33 -0.01 1.34 1
23 1.52 -0.85 1.36 1
24 1.47 -0.91 1.38 1
25 2.27 -0.13 1.4 1
26 3.18 0.76 1.41 1
27 3.39 0.96 1.43 1
28 2.72 0.27 1.45 1
29 1.8 -0.66 1.46 1
30 1.49 -0.99 1.48 1
