<operator name="Root" class="Process" expanded="yes"> <parameter key="resultfile" value="/home/rm_workspace/p2/resultat.res"/> <operator name="InputHistorik" class="ExampleSource"> <parameter key="attributes" value="C:\Program Files (x86)\Rapid-I\RapidMiner-4.3\historik"/> </operator> <operator name="NearestNeighbors" class="NearestNeighbors"> </operator> <operator name="InputHistorik (2)" class="ExampleSource"> <parameter key="attributes" value="C:\Program Files (x86)\Rapid-I\RapidMiner-4.3\historik"/> </operator> <operator name="ExampleFilter" class="ExampleFilter"> <parameter key="condition_class" value="missing_labels"/> </operator> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator></operator>
How I can do it?
The correct result would be the second row of the first file . Value: 123
<operator name="Root" class="Process" expanded="yes"> <operator name="CSVExampleSource" class="CSVExampleSource" breakpoints="after"> <parameter key="filename" value="C:\Users\CJFP\Documents\rm_workspace\historik.txt"/> <parameter key="read_attribute_names" value="false"/> <parameter key="label_column" value="2"/> <parameter key="id_column" value="1"/> </operator> <operator name="IOMultiplier" class="IOMultiplier"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="ExampleFilter" class="ExampleFilter"> <parameter key="condition_class" value="missing_labels"/> <parameter key="invert_filter" value="true"/> </operator> <operator name="NearestNeighbors" class="NearestNeighbors"> </operator> <operator name="IOSelector" class="IOSelector"> <parameter key="io_object" value="ExampleSet"/> </operator> <operator name="ExampleFilter (2)" class="ExampleFilter"> <parameter key="condition_class" value="missing_labels"/> </operator> <operator name="ModelApplier" class="ModelApplier"> <list key="application_parameters"> </list> </operator></operator>
Your code it's not the solution. I woultd compare the atribute 3-7 of file 1 with atribute of file 2 and the result there is atribute 2 of file 1.
