No results after Optistruct and Multiscale co-simulation
Hello all,
I'm new user in Multiscale designer.My aim is to create material model in Multiscale designer and of course for fiber orientation data I used Inspire mold(I have no problem about that)But in Hyperworks interface,I prepared my model for nonlinear analysis with multiscale material model and when I started solution ,as you see I got this message " job completed" without results and with any errors.What is the problem?
In addition my run directory is:
Please help me for the issue. Thanks in advance.
can you sahre the .out file of OptiStruct?
Is there anything unusual there?
What version are you using, and what kind of license do you have?
0 -
Adriano A. Koga_21884 said:
Hello Adriano,
Thank you for the feedback ,in attached file I share and also I use 2021 student version.
0 -
In addition There is no unusual situation.If you want,I can share fem file.
0 -
HI, Can you confirm you have the installation directory set in the settings (gear symbol)
0 -
Hello Mr.Ponginan,I hope you're well.As you see below,same your inst. directory.I have limited time and really need help about this.
