I have a data extract from one of our systems, in which I'm attempting to find any lowercase values in a particular column.
I see in the help file that this cannot be done using a function comparison in a filter, i.e. "Field = lower(Field)", as filter expressions are not case-sensitive.
So I'm trying to accomplish it using a lookup table, where I've entered 26 input values, one for each lowercase letter, using "Input Field Contains Input Value" for matching (rather than "Exact") and have Case Sensitive checked. When I do this it pulls the lowercase fields, but also a bunch of uppercase values as well. (But not the entire dataset.)
Is there any way to accomplish what I am trying to do in Monarch?
Thank you for your assistance.
