I want to use HIL on Embed to monitor the acceleration of the XYZ axis in real-time. The program runs correctly in the Arduino IDE environment, but I cannot convert the code to blocks in the Embed environment. Can you tell me how to set it up? Thank you.
Hi Robert, Could you please try the attached diagram. I have modified it to compile the ADXL354 looking at you originial diagram. Do not have a sensor to test it out but hoping this should work.
--sreeram
