What is the method to use a Proximity Sensor in Motionview?
User: "Brian Murray"
Altair Community Member
Updated by Brian Murray
I've been unable to find a way to apply a Proximity Sensor in Motionview. Are there any examples of using this functionality? Is this only available in Inspire?
Sensor: Proximity Model Element The Sensor_Proximity element defines a sensor between two bodies which monitors their minimum separation. The sensor tracks the state of interference of the two bodies, the minimum distance between them, and the coordinates of a pair of closest points. These quantities can be accessed using the PROXIMITY function for use in defining expressions or for plotting.
Thanks
1 - 1 of 11
    User: "Praful"
    Accepted Answer
    Updated by Praful
    Hi Brian - Sorry, I did not realize you were using the new interface, where this feature is not rightly supported in the Live run version.
    You may use the Offline mode.
    Regards
    Praful
