I'm working with Rapidminer 4.3 in that project
<operator name="ArffExampleSource" class="ArffExampleSource" breakpoints="after">
<parameter key="data_file" value="C:\Input.arff"/>
<parameter key="id_attribute" value="1"/>
<parameter key="label_attribute" value="example6"/>
<operator name="InteractiveAttributeWeighting" class="InteractiveAttributeWeighting">
<operator name="Learn" class="OperatorChain" expanded="yes">
<operator name="W-NaiveBayesUpdateable" class="W-NaiveBayesUpdateable">
<operator name="ModelWriter" class="ModelWriter">
<parameter key="model_file" value="C:\model.mod"/>
<parameter key="output_type" value="XML"/>
<operator name="ArffExampleSource (2)" class="ArffExampleSource" breakpoints="after">
<parameter key="data_file" value="C:\Prediction.arff"/>
<operator name="ModelLoader" class="ModelLoader">
<operator name="ModelApplier" class="ModelApplier">
with input.arff...
@RELATION Input
@ATTRIBUTE Id numeric
@ATTRIBUTE example1 string
@ATTRIBUTE example2 string
@ATTRIBUTE example3 string
@ATTRIBUTE example4 string
@ATTRIBUTE example5 string
@ATTRIBUTE example6 string
@DATA
'1','ex1','hello4','hw1','false','1000k','slow'
'2','ex1','hello6','hw2','true','4000k','slow'
'3','ex1','hello2','hw3','false','500k','slow'
'4','ex1','hello3','hw3','true','2000k','slow'
'5','ex2','hello2','hw2','true','500k','slow'
'6','ex2','hello5','hw1','true','1000k','mid'
'7','ex2','hello2','hw3','false','4000k','fast'
'8','ex3','hello','hw1','true','2000k','mid'
'9','ex3','hello','hw2','true','4000k','fast'
'10','ex3','hello','hw3','false','2000k','slow'
'11','ex3','hello','hw1','false','500k','mid'
and prediction.arff.....
@RELATION Prediction
@DATA
'100','ex1','hello','hw1','false','1000k'
'101','ex1','hello2','hw2','true','4000k'
'102','ex1','hello','hw2','true','4000k'
'103','ex1','hello2','hw3','true','500k'
'104','ex1','hello','hw2','true','2000k'
'105','ex1','hello2','hw1','true','4000k'
'106','ex2','hello3','hw1','false','500k'
'107','ex3','hello3','hw2','true','4000k'
'108','ex3','hello4','hw3','true','500k'
'109','ex3','hello5','hw3','false','500k'
'110','ex3','hello6','hw2','true','500k'
'111','ex3','hello2','hw1','false','500k'
'112','ex3','hello6','hw1','true','500k'
when I execute the program, at the results, I click on "Data View" of the "Data Table" and the values of the colum "example1" are differents of the prediction.arff example1 attribute.
Anyone can help me?
Is only a print error, or affects too in the learning operator?
Thanks in advance.
Cheers,
Jorge
